yesterday
Hello everyone and happy Spring!!
I was wondering if there is a way to have an insulation at a slab's edge. Meaning the perimeter part - excuse my English Iam not very good in technical terms.
I make the plans of a 3 storied building and I have insulation outside the walls and in reality the insulation is also at the slab edge
Operating system used: Windows 10
Solved! Go to Solution.
yesterday
Hi!
To answer your question: no. Slab composite stack layers vertically not horizontally.
In your case, your wall would continue so that it meets the one above (and thus the thermal layer would be continuous).
And if you want the slab or contour beam there to show up over the masonry, you can do that via the material priority settings.
More on that here: https://help.graphisoft.com/AC/26/INT/_AC26_Help/025_Attributes/025_Attributes-18.htm
yesterday
Hi!
yesterday
Thank you so much for your prompt answer! Yes with the walls works fine, slabs are structural concrete so stronger for walls bricks, so I put the bottom of the wall to the lower side of the slab and it worked like a charm!
Have a nice evening!
