rozky
Solid element operation doesnt work wit D+W13
Hi
i want to subtract composite floor with wall
I set doors lower oversize to get proper detail in the doors section
when i use doors13 it doesn't works, with doors12 it woks fine
Is it a bug or...
Ryzen Threadripper 1950X - 64GB RAM; NVidia GTX 1080Ti ; Windows 10 64bit; AC10-AC23 (64bit)
11 Replies 11
Frank Beister
I tried it now for an hour. I compared the XML-version of some used macros, but didn't find something obvisiously.
The trick will be something like
IF GLOB_CONTEXT=44 then...
This is the case the script is executed for a s/e AND for doing the SEOs. But I haven't found it in the scripts. So GS has forgotten this case, when they extended the d/w from 12 to 13. I have reported it.
rozky
thank you
