Stair in ac13
Hi There,
I was wondering if anyone knew how to make custom stairs in archicad 13. It was simple in 12 when you entered the height details and could simply move the stair wherever one wished, but this does anyone know how to do this in AC13?
Many thanks,
FINN
TMA_80
Hi!
AFAIK, the stairmaker has not been updated in ArchiCAD13 , so there is no difference between the 12&13 version .
i think that you're talking about the stair library parts , when you open the stair options instead of creating stair, explore the librayr (left part of the window) and you should find the library stair objects.
AC12_27 |Win11_64bit|
Draw the Floor Plan view of the Stair using a Fill and draw the travel line with a Line Tool (but not the Polyline Tool). Then select them and use the Design\Create Stair Using Selection menu command.
Check the Help files for more information.
