Stairs not visible in relevant stories
adrianasofiasm_
Hi!
I have some stairs going from story 1 to story 2, and in the settings I have them to be viewed on one story and one story up, but when I go to the second story plan, the stairs don't appear. Am I missing something?
Thanks!
AC27 USA - MacBook Pro 14" - Apple M1 Pro - 16 GB
Hi @adrianasofiasm,
I guess you drew the stair from up to down so its appearance is flipped,
If you drew from down to up it'll appear correctly.
AC 28 INT 3110/WIN 11
Lingwisyer
Guru
Given when your stair is showing it is showing as hidden, I suspect that your linked stories are incorrect. Do you happen to have a negative Home Story offset?
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
