2012-04-27 10:00 AM - last edited on 2023-05-26 12:30 PM by Rubia Torres
2012-04-27 01:27 PM
2012-04-27 06:16 PM
2012-04-27 06:54 PM
2012-04-28 01:57 PM
2012-04-28 02:38 PM
Nicola wrote:I'm not sure if this matches what you're after, but OBJECTiVE includes both tapered and cambered beam types (refer to the attached image). The extent of the camber is fully parametric on the top and bottom (in either direction) as is the extent of the taper.
I have to make beams with variable section as you can see in attached image. How can I do?
2012-04-28 04:10 PM
2012-04-29 09:52 AM
2012-04-29 10:37 AM
2012-04-29 01:16 PM
