Wall-Opening - Composite Slab: Behaviour of first skin
wkrt-hs
Hi!
I just discovered that the top skin of a composite skin is never pulled into an opening. No matter of changing the z-position or type (core/finish/other). Both slab materials have lower priority than the wall material.
Also, if I change the remaining layers to core, they're also not pulled in.
Only solution was to add a 0 mm top skin, but that's not a clean solution.
Any ideas on this? Where can I find information on this in the manual?
Best, Wenzel
1 REPLY 1
Steve Jepson
Sometimes - the "clean solution" (for me) is to model all the elements of the floor as individual, geometrically correct parts.
