Walls have weird cutout in section view
Have never seen this one, am modeling as-builit 2 bdrm/2 bthrm home w/attached garage that steps down...
The walls of the garage have what looks like a negative space in Section View that is the height of the slab, which is under them...what did I do wrong...have checked the renovation filter set to 'existing'... See pdf below...???
5 Replies 5
Is there a slab in a hidden layer that is cutting the walls?
alemanda
... or has your section line a step? so you cut the roof along a line until a certain point and the the section continues along another line where the roof has other slope ...
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
Looking at your walls they don't have any cut fill and the contours are thin, so I suppose the walls are not cutted by the section, but are shown in a view, so they might be trimmed by the roof at some point in the background where the roof pitch goes down.
fuzzytnth3
Looks like the walls are interacting with another element such as a beam or slab or you have duplicated a wall into that location.
I would check the 3d view to see if there are walls in that location. Next switch all the layers on and see if there is a slab interacting with the walls.
If the other element has to remain where you have it then you can use a Layerset that sets the Layer priority to have a different layer number
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
rgarand
Looks like your section line, in plan, is not straight.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
