LeeJaeYoung
What criteria does Check Duplicates work on?
Check Duplicates Add-On - Graphisoft Community
Even if you select it, it will not be checked.
before deletion
after deletion
AC27 on window 11
6 Replies 6
The article says deletion works only in the Floor Plan Viewpoint. You seem to be trying to do it in a Section or Elevation Viewpoint.
Can you try it in the Floor Plan?
LeeJaeYoung
I deleted it once.
I guess I should have had it.
And when I intentionally overlap them and test them, it seems that they overlap even in the elevation.
I think it's more like what I posted because it suddenly came up without recognizing that I overlapped it.
Still, I'm glad I'm not a ghost.
There was a ghost among the posts I posted.
So I had to remove the wall and practice again.
AC27 on window 11
Elements must be exactly the same element in exactly the same position for them to be treated as a duplicate.
Different elements that occupy the same exact position (i.e. different wall composites) will not be considered as duplicates.
Likewise overlapping elements are not duplicates unless they are exactly the same size and shape and in exactly the same position.
LeeJaeYoung
overlapped exactly.
The above picture before deletion is just two overlapping lines showing more lines.
AC27 on window 11
If they are 'Lines' and they are exactly the same line type, pen colour, layer, length, etc., then they should be counted as duplicates.
If they are not lines (i.e. they are walls, beams, columns, etc.) then they will not be selected as duplicates in a section or elevation as Laszlo said.
3D elements can be selected as duplicates in the 3D window.
