What should I do if the wall connection is abnormal?
LeeJaeYoung
What should I study?
https://drive.google.com/file/d/158ynHLPPX5e80R6cT3n_r6ao9nTRd8Iu/view?usp=sharing
AC27 on window 11
Hello LeeJaeYoun,
Here is some image of the principle of a custom post to join 4 walls.
Capture d’écran 2022-06-11 à 20.05.12.pngCapture d’écran 2022-06-11 à 20.05.06.pngCapture d’écran 2022-06-11 à 20.07.03.png
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
12 REPLIES 12
Hello LeeJaeYoung,
Despite moving the reference lines of each wall (in pairs), I did not manage to create a perfect match and I came to a radical and effective solution. I make a personalized column profile on which the 4 walls are connected without crossing.
Christophe - FRANCE
I see this post will benefit you much
https://community.Graphisoft.com/t5/Design-forum/Composite-walls-wrkflow/td-p/326159
AC 27 INT 5060/WIN 11
I don't quite understand.
I would appreciate it if you could show me a more detailed explanation or image.
AC27 on window 11
Hello LeeJaeYoun,
Christophe - FRANCE
thank you ^^
What you're saying is that it's good to have a complex column at the joint point.
Is this the default way in Archicad?
With columns and walls ...solve all planes.
May I ask you one more question?
How do you deal with liquid waterproofing and wallpaper?
I'm thinking of treating the liquid waterproofing with Morph.
However, I am thinking about what to do with the wallpaper.
AC27 on window 11
"What you're saying is that it's good to have a complex column at the joint point."
You are right but what I am saying is to get a solution about your request 😉
Please note that it is nevertheless necessary to plan to modify the classification of the connection column. It is not a column but a wall which must therefore be exported as type ifcwall.
"Is this the default way in Archicad?"
I do not think so ! It is mine for sure.
"How do you deal with liquid waterproofing and wallpaper?"
I use SEO to get watter into a gsm object about a pool or watter into a mesh to get a pond.
About wallpaper I only use model tab like below but you are able to use morph too.
Christophe - FRANCE
Thank you so much
AC27 on window 11
I'll ask you one more question ^^
How do I get the concrete face treatment process to appear on the schedule?
Concrete Face Treatment: To level the concrete surface by grinding the concrete surface.
AC27 on window 11
LeeJaeYoung,
I am not able tu understand your request with my poor english 😕
Christophe - FRANCE
