Window / Door Marker saved as a Fovourite
Is there a way to save a window/ door marker as a favourite so that I can apply just the markers parameters to a different window?
6 REPLIES 6
Unfortunately no.
What you can do is open the Door/Window Marker for editing.
There you will see the list of parameters. Set them to the desired values and save it as a new Door/window Marker.
Do this with every Favorite style you need.
You will then have these Marker styles available for Doors/Windows. When you want to choose one, just select that Marker and it will default to the parameters you saved it with.
Thanks Lazlo. How do I open the Door/Window Marker for editing?
David Maudlin
John:
Go to Open Object by Subtype, then navigate to the Window-Door Markers to select the Marker you want to modify.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Where would I find the 'open by subtype' command? I can get a direct 'open object' dialogue, but the menu displayed in David Maudlin's screen-grab is elusive.
Thanks for your help
OSX 10.6.8 + AC14EDU
You either need to edit your Work Environment to include this command in the menus or just open the "Edit GDL Library Parts" toolbar (WINDOWS menu > TOOLBARS).
It should be the 6th button along.
Thank you Barry!
