Window forming corner
I would like to know if there is a way of drawing a window with several interior frames which goes through a corner as well. I know that is possible using the curtain wall tool, but this is not an architecture curtain wall, just a fixed window that comes to a corner and turns.
Erwin Edel
You can make corner connections with most windows and window openings, you can make glass on glass corner connections with the 'repeating x' window type.
In the Dutch library, the settings for these are towards the end of the list of settings, just after the sunscreen options.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Dontknow
You mean something like this:
You can find it in your 'Window selection settings':
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
You can use the 'corner window' tool as well but both windows will be identical.
Better to use separate window objects and turn on the corner window settings as mentioned.
