Windows in Composite Structures
I wonder if any could advise if there is a method of closing cavity walls at windows.
I have a brick cavity block and plastered wall and wonder if its possible to close the block against the external leaf of brick in the conventional construction method.
1 Reply 1
Can you show a screenshot, please?
Also, please state you AC version number, not only its build number.
