Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
2010-08-0907:16 PM - last edited on 2023-05-2602:36 PM by Rubia Torres
I wonder if any could advise if there is a method of closing cavity walls at windows.
I have a brick cavity block and plastered wall and wonder if its possible to close the block against the external leaf of brick in the conventional construction method.
