2006-10-05
01:54 AM
2023-05-26
03:03 PM
Rubia Torres
2006-10-06 12:32 PM
~/archiben wrote:Not in my book. It is consistent, until the Stories are the main vertical identification. Speaking of Revit, until the Levels are implemented (I hope never) that can or not have implication of a Storey or a plan, it should be like this.
ah - there's the problem. unfortunately, is this another case of our "consistency" lecture shooting ourselves in the foot again?
~/archiben wrote:Installed XP already?
yeah. can you believe it? revit here i come . . .
2006-10-09 11:29 PM
Djordje wrote:i'd done that by day 4 with the MBP! but i was running it through apple's boot camp, so didn't really have the inclination to dual boot. but now that parallels is stable, officially release and patched, i've installed that. still on trial at the moment, but i don't think it will be long before i buy the license.
Installed XP already?😉
BTW, both 9 and 10 work on MBP under XP ...anything that runs on win XP will run on win XP through parallels, so yeah: both 9, 10 and revit all fire up without any trouble . . .
2006-10-10 12:00 PM
~/archiben wrote:Ben, can you run AC 10 in XP and in OSX simultaneously under Parallells? No Wibu key issues?BTW, both 9 and 10 work on MBP under XP ...anything that runs on win XP will run on win XP through parallels, so yeah: both 9, 10 and revit all fire up without any trouble . . .![]()
2006-10-10 11:31 PM
Thomas wrote:ah. no. unfortunately parallels does steal my WIBU key from the mac OS and doesn't give it back too easily.
2006-10-10 11:40 PM
~/archiben wrote:Sigh...
2006-10-29 08:58 AM
2006-10-29 11:24 PM
Martin wrote:i haven't - but i will next time i get a chance to play around a bit . . .
Stupid question but have you tried removing the key & then reinstating it when in Parallels may be worth a shot.
(i am not sure why any one would want to bootcamp into Windows camp) when there is Parallels)simple. performance and hardware sharing. although parallels is not doing much emulation because the chips are intel now, there is still a minor performance drop in running one system inside another. combined with the memory handling (two 'systems' using addressing the RAM at the same time?) and hardware issues like the WIBU key thing above, booting directly into windows is always going to be the preferred option when using 'pro-app' heavy duty processing stuff . . . for the moment . . .
2006-10-30 06:54 PM
2006-10-30 09:50 PM
Gerald wrote:bootcamp is essentially a hardware-driver generator for your specific hardware setup. i think they've got most of it nailed now, but i doubt we'll see the real-deal, gold-master drivers from apple until they release bootcamp officially as a part of leopard (OSX 10.5). i believe it's due in the first quarter next year(?) i would imagine - i don't know for sure - that parallels piggybacks the bootcamp driver development?
I was under the impression that there was a performance hit in Parallels with video. Is this true or has that been corrected. I think it was due to a lack of video drivers for Windows or was this just in Bootcamp?
I have a 24" Dell panel which I would hook up to in the office but would want to be sure I can run it in native resolution and that there wouldn't be any issues with OPEN GL.dual-monitor problems such as this are actually more dependent on the graphics card in the machine you opt for . . . the trouble with macs is that you
"Apple MacBook Pro 17" Tech Specs" wrote:
Dual display and video mirroring:
Simultaneously supports full native resolution on the built-in display and up to 2560 by 1600 pixels on an external display, both at millions of colors
I would rather run AC in Windows until they fix the lack of docking in the Mac so I would not want to take any performance hit.but have you tried the mactel build of archicad running on intel chips from within OSX?! might make you reconsider your (minor?!) palette docking issue?
2006-10-30 09:55 PM
