can you convert lines to be able to see them in a 3d window
just wondering in archicad, if i can insert title boundary lines into a drawing and be able to see them in the generic axonometry view. like what is attached.
these title boundary lines were photoshop in
i want to be able to not use photoshop to get this affect in archicad
any help would be great
4 REPLIES 4
I use grid lines to do this, just turn off markers in both 2d and 3d
Regards,
Scott
David Maudlin
millarm:
The Morph Tool can be used to draw lines that will show in both 2D and 3D. Being just lines, they do not render.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Erwin Edel
You could try saving your 3d view as a 3d document and annotate that.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
I presume this method would still work - http://www.archicadwiki.com/HowToSuperimpose2dFloorPlanOnto3dModel
I don't know if the lines would display in a 3d document, as the above article states that it only works in the 3d window in openGL mode, but it's an old article and things change so give it a go and see what happens!
