creating a circular roof
In my building design I needed to create a fake roof so that I could trim some walls. That worked great on the straight portion of the building but the inside of my building requires that I do the same thing but in a curved corner. Thus I need to create a roof that will sweep through a 90 degree arc such that the smaller arc is at the bottom of the roof (think of the corner of a football stadium). At first I thought I could just drag a copy of one of the already trimmed walls but without the roof structure the trimming is lost requiring me to create a fake item and then hide it. Doesn't seem to be too intuitive and is creating a lot of extra work for me. I have looked all over the ROOF tool but there doesn't seem to be any options to choose for curved/circular roof structures. All suggestions welcomed.
3 Replies 3
Steve Jepson
It is possible that a roof is not your best option to trim the walls. Perhaps you can use SEO better. ? Can you show a picture of what you want to do? We haven't had the circular roof tool in ArchiCAD for many years.
A curved roof (in plan) can still be created using the roof tool but it will be a series of small flat panels (as it always has been).
Domed roofs are now done with the shell tool.
If you need a more accurate cone shape or dome then use an object (primitive shapes) or the shell tool.
The shell tool can also use the connect > trim to roof/shell command and will use the shell cutting body like it does for the roof (see your other post).
http://archicad-talk.graphisoft.com/viewtopic.php?t=58857
Or again SEO may give better control.
With SEO you can use anything to trim - roof, shell, slab, morph, complex profile wall/beam, etc.
It is just a matter of getting the form you need to use as the operator.
Guru
You can make curved roofs atm by curving the pitching point and/or eave. I don't think you can make a donut though.
Ling.
