Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
help! Roof on freeform shape
looking to put a roof on this, not sure how or where to start, originally wanted to have a sort of corrugated metal roof.... any ideas?
22 REPLIES 22
i am also unsure how to cut a hole in the slab using the wand tool, i can do it with the seo but thats not really doing the same thing..
on the pett pallet i have only drag, rotate, mirror, elevate and multiply...
HELP! 🙂
thank you
ive got the hole in the floor slab now, 🙂
just need to know how to make it bigger for the overhand, then im sorted! 😉
i hope,
David Maudlin
joeish wrote:
1 question, where is the perimeter expansion tool?
On the pet palette.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
