how do I increase mesh size while keeping topography
Ed455678
I have made a mesh after importing a topographic map into Archicad 28, but when I tried to increase the size of the mesh, the topography won't increase as well. Is there a way I can increase everything at the same rate?
Thanks
If I understand correctly, you have created user-defined Ridges on the Mesh based on the ridges of the topographic map. But now that you want to make the mesh, let us say, 50% larger, those user-defined Ridges will stay where they are, and their positions do not change as you would expect when resizing.
To achieve that, you could convert the Mesh to a Morph, and then you could resize the Morph, and all its geometry would resize proportionately.
Guru
Though you really should scale anything you import before you use it...Morph representation and modification is a pain...
