‎2025-05-25
02:01 AM
‎2025-05-25
06:17 PM
I have made a mesh after importing a topographic map into Archicad 28, but when I tried to increase the size of the mesh, the topography won't increase as well. Is there a way I can increase everything at the same rate?
Thanks
‎2025-05-25 06:33 PM
If I understand correctly, you have created user-defined Ridges on the Mesh based on the ridges of the topographic map. But now that you want to make the mesh, let us say, 50% larger, those user-defined Ridges will stay where they are, and their positions do not change as you would expect when resizing.
To achieve that, you could convert the Mesh to a Morph, and then you could resize the Morph, and all its geometry would resize proportionately.
‎2025-05-26 03:07 AM
Though you really should scale anything you import before you use it...Morph representation and modification is a pain...
