2012-03-10 10:23 AM - last edited on 2023-05-26 02:28 PM by Rubia Torres
2012-03-10 12:01 PM
2012-03-10 03:53 PM
2012-03-10 04:15 PM
2012-03-10 06:30 PM
2012-03-10 06:35 PM
Chazz wrote:Chazz,
But let's be honest about this. There are MAJOR bugs with this area of the software. In fact, in my work, camera/view hassles are the number one most consistent, most annoying, most disruptive and most time-wasting issue in ArchiCAD.
Please GS, fix these LONGSTANDING bugs and inconsistencies. The 3D Documents looked like a step in the right direction but the limitations with materials makes that tool too crippled in lots of situations. V15 did make some progress to the corruption in layouts issue but camera/views is an area of the program that, after more than a decade of no change, needs to be completely rethought.
2012-03-10 06:43 PM
2012-03-10 06:50 PM
Karl wrote:Aloha Karl,
I find saving views to be the easiest solution. Create just like any other view - either right click/save view from navigator, or drag camera to view map in Organizer.
No problem updating views either - just open the view, modify as desired, then from open the view settings and get current window settings.
Karl wrote:
I haven't touched this area in years, using Artlantis instead,
2012-03-10 07:02 PM
Chazz wrote:Not sure I understand, Chazz. AFAIK, nothing has been improved/changed about 3D views or cameras since v11. But, my coffee hasn't kicked in yet today.
Of course, in my rant, i never directly addressed John's issue. In truth, I think that if your sig is up to date and you still are using V11, you may be in for a world of hurt.
2012-03-10 07:07 PM
TMA_80 wrote:This works exactly, perfectly.
There is however a cleaner way ...
once the modified angle is OK
Navigator/Generic perspective/save current view
this will create a view that you'll find on the "view map" part of the navigator
