merge fills
hi all I change elevation from 3d to 2d(draw)
how can I merge fills witch has same properties in one single fill ?
19 REPLIES 19
For me it's easier to transform section/elevation form 3D to 2D, and to complete the drawing in 2D (add new hatches, lines, description, finishes). In firm where I work for, don't put too much value on section/elevation 3D.
Rarely I saved a few pictures from a 3D building.
I forgot to say that I'm working in AC 11.
...and HAPPY NEW YEAR FOR ALL...
Steve Jepson
Krippahl wrote:
Djordje wrote:
and try to NEVER turn the elevations into the 2D drawings ...
second
third ! It is never necessary or helpful.
Eduardo Rolon
Steve wrote:
Krippahl wrote:
second
fourth
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Rod Jurich
ejrolon wrote:
Steve wrote:
Krippahl wrote:
second
fourth
.............. 5th
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
................... 6th
7th.
Turning 3D into 2D makes you lose advantages of BIM.
People do this (I used to as well) because it seems like it is easier, and most people start out learning 2D, and that's what they stick with. It takes some time to learn how to get 3D drawings to look good like a 2D drawing can, but like I said before, it is definitely worth it. We put in the time and it's paying off. I also think you have to go 3D just to be competitive. A lot of firms now are, and in a few years, a lot more will be.
If a client wants a 3D model with fly-throughs and renderings, you'll be S.O.L.
What is S.O.L.?
It's abbreviation for something?
Yes, sorry, a slightly crude American abbreviation meaning you're "out of luck".
"Google" it.
