ā2012-12-12
05:29 PM
ā2023-05-23
04:33 PM
Rubia Torres
ā2012-12-13 05:44 PM
RESOL 16This will set the resolution of curves to 16, resulting in much less polygons.
ā2012-12-14 02:34 PM
laszlonagy wrote:Laszlo:
If the polygon count is high then maybe the GDL script should be modified.
Resolution of curves is 36 by default, which means a simple cylindrical shape is at least 36 polygons, a simple shere is 1296 (36x36) polygons.
You can place a command at the beginning of the 3D Script, for example setting the resultion to 16 (which means a full circle will be made up of 16 segments):
ā2012-12-14 02:51 PM
ā2012-12-14 04:49 PM
ā2012-12-14 04:53 PM
ā2012-12-14 05:07 PM
ā2012-12-14 05:25 PM
ā2012-12-14 05:26 PM
ā2012-12-14 05:28 PM
