‎2011-11-21
11:42 AM
‎2023-05-23
02:45 PM
Rubia Torres
‎2011-11-21 01:07 PM
‎2011-11-21 06:33 PM
‎2011-11-21 06:48 PM
Steve wrote:Aloha Steve,
To be clear about your question we need to know if your are talking about how to show that in Layout (the prints) or how to see that while your working on the model. I assume you mean in Layout.
In Layout you can assemble many views into the same drawing so virtually any thing you want to see is possible. It's just a mater of draging the views you have made to show what you want into the drawing and perhaps making one view display on top of the other.
If I understand what your asking about, we can already do that.
‎2011-11-21 08:33 PM
‎2011-11-21 09:00 PM
‎2011-11-22 04:44 AM
I am always able to see what I want when I want to see it and I think you can too. It's just a matter of where you model things and what you use to model them with.
Perhaps the view your after would work better if you don't model the roof or the roof framing on a different story than the walls. You can model things on one story and have them display on another.
something like this ?
http://archicad-talk.graphisoft.com//files/first_floor_framing_plan_112.pdf
‎2012-05-01 07:12 AM
s2art wrote:The
.... why not be able to turn display of lines on and off per edge as well? Obviously turning all edges off could be a problem, but a warning if this was to happen, or "display only" (non-printing) edges would be helpful. Then, for a solution to your request John, you could add a node part way up your hip / valley, and turn the upper part of the line off.
‎2012-05-02 06:22 AM
‎2012-05-02 04:08 PM
