ā2022-11-14 01:43 AM
Hello. Need to make a solid el. op. using extrution both up and downward. If I do on after de other, the first result just loses the opertation itself. Any ideas? Thanks!!!
Solved! Go to Solution.
ā2023-02-27 03:01 PM
Did you script the skylight object?
If so you can add a PRISM that extend above and below the skylight and have it so it is only active when a Solid Element Operation is activated.
The PRISM itself will never show but it will cut what ever it passes through.
if GLOB_CONTEXT > 40 and GLOB_CONTEXT < 50 then
PRISM_ ......
endif
Otherwise if it is a standard skylight and you placed it with the skylight tool, it will cut a hole in the roof and if those tiles are a roof accessory, it should cut those as well (I can't say I have tried it though - I never model roof tiles).
ā2022-11-14 01:53 AM
Have you tried 'Intersection' instead of subtract up/down?
That sounds like what you are trying to achieve.
ā2022-11-14 02:22 AM
Intersection will just remove any parts of the target which are not bound withing the operator.
ā2022-11-14 02:28 AM
Maybe for the subtraction downwards you can use your typical SEO command while for the subtraction upwards maybe you want to use a roof then CTRL+0. š
ā2022-11-14 02:35 AM
Maybe @Alexandre dias can show us an image of what they are trying to achieve?
If they want to keep the upper and lower portions then a simple 'Subtract' would suffice?
I took it that they were trying to remove both the upper and lower portion which would leave you with the intersection.
ā2022-11-14 05:13 AM
He wants to have the effects of both subtract with upward extrusion and subtract with downward extrusion, with a single operator (as if using the opening tool, or cutpoly; the result can get more complicated with a modeled operator, as opposed to a 2D outline). I had never noticed you can't by just doing one operation after the other.
ā2022-11-14 05:27 AM - edited ā2022-11-14 05:28 AM
Yeah... find it odd that the two operations, subtraction with upward and subtraction with downward, are mutually exclusive...
ā2022-11-14 06:24 AM
I am still not sure what @Alexandre dias is exactly trying to do.
With only one target and one operator, you can only apply either subtraction with upward or downward extrusion only.
You can't apply both.
You need two operators to do that.
ā2022-11-14 10:46 AM
It's an interesting question? In the real world it is counter intuitive to building in that you have remove both support & suspension options. For modelling there is some logic, but in all the years of SEO being available I have never noticed it missing. The obvious questions assuming this is a "Beam" passing through an element would be:
1. Can you split the element horizontally to allow the SEO to be applied to two elements.
2. Can the element be split vertically to pull them either side of the beam.
3. As has been suggested above, does the opening tool not deliver a solution, even though it is not tied/associated with the beam?
A bit more context would help?
ā2023-02-27 01:46 PM
Hi, Thanks a lot for each answer I got and sorry it took so long to come back to you guys. What I'm trying to do is to cut the roof, both roof tiles and wood framing in an area I previewed a skylight. Image attached. Thanks again.
