2010-06-21 12:19 PM
2010-06-21 08:16 PM
2010-06-23 07:45 AM
laszlonagy wrote:DELL 3007WFP on NVidia GeForce 9800GT
Just out of curiosity: what is the size of your display and the resolution you are using?
2010-06-23 10:18 AM
2010-06-23 03:15 PM
Brett wrote:
I have a 30" screen set at that resolution. I'm using Win7 and have the Display set at 125%. i.e. Control Panel/Appearance and Personalization/Display. Screen Perfect in ArchiCAD.
Only down side is that the Tool tips in ArchiCAD don't work. Very Annoying. Graphisoft know about the bug, and I was told it wasn't a priority to fix.
2010-06-23 11:30 PM
krzystoff wrote:Try turning off 2D Hardware Acceleration which in turn turns off Antialiasing. Works for me
I've tried the 125% scaling, and it may be an effect of the video driver, Windows XP, or a peculiarity with Dell screens, but the anti-aliasing is quite awful from a normal viewing distance ~30cm.
2010-06-24 11:23 AM
Brett wrote:krzystoff wrote:Try turning off 2D Hardware Acceleration which in turn turns off Antialiasing. Works for me
2010-06-24 12:33 PM
2010-06-24 02:48 PM
laszlonagy wrote:
Until this issue is resolved, there is a trick on Window you can do to increase the font sizes in ArchiCAD.
HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 13.0.0 INT R1\Font Description
There are three kind of fonts you can change: large, Small and Extra Small.
After such a modification, I think you will have to restart ArchiCAD for the changes to take effect.
2010-06-25 02:59 AM
