License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
what determines how a wall wraps around a column?
Espen da Silva
I'm creating a wall that crosses a collumn, and the collumn has "wrapping method" turned to "freestanding, wrapped", giving the following result:
As you can see, only some of the layers of my profile wall are wrapping around the collumn, namely the brick and the air layer (sorry for the norwegian):
The "freestanding, wrapped" method icon seems to imply that it's possible for some layers to wrap around the outside of the collumn (like the brick in my example), and other layers on the inside, which is what I hoped my insulation and gypsum would do. Why are only two of the layers wrapping around my collumn? Is it the "core outside" "core inside" layers that determine this?
EspendaSilva_2-1714382907582.png                 EspendaSilva_3-1714382921285.png           EspendaSilva_4-1714382993292.png          EspendaSilva_5-1714383083649.png|
Hi @Espen da Silva,
Take a look at this topic you may find an answer for your question.
https://community.graphisoft.com/t5/Modeling/Composit-wall-not-wrapping-correctly-in-3-D-view/td-p/5...
AC 27 INT 5060/WIN 11
I think you will find it is only the 'finish' and 'other' skins that wrap in 2D.
Your internal gypsum and insulation are set as 'core'.
In the 3D view, you will not see the skins wrap, but the column size will increase correctly and the external surface will wrap.
