The three walls make a connection, the column just sits 'on top' of it, as it were. The wall connection gets processed first, I think.
You could:
- change the material priority of the masonry or insulation, to stop the insulation going through with the wall connections
- draw the column with a wall, breaking up the connection of the 3 walls, by putting the 4th bit of wall in between
- patch over the unwanted insulation with a 2d fill
www.leloup.nlArchiCAD 9-29NED FULL
Adobe Design Premium CS5
