wrong insulation connection
Hi. The angled wall has insulation and must stop to the column. But as you can see in the attached pdf the insulation pass through the column. Any ideas;
Erwin Edel
The three walls make a connection, the column just sits 'on top' of it, as it were. The wall connection gets processed first, I think.
You could:
- change the material priority of the masonry or insulation, to stop the insulation going through with the wall connections
- draw the column with a wall, breaking up the connection of the 3 walls, by putting the 4th bit of wall in between
- patch over the unwanted insulation with a 2d fill
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thank you!!!
