Stephen Dolbee
AC18-date of issue
In AC17 and prior, "date of issue" could be found under File/Info. Does anyone know where it is in 18? Something to do with revision manager?
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
5 Replies 5
Stress Co_
I'm not up to speed with revision manager,... but you could re-create it by using the "add" button.
It'll appear in your auto text list.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Eduardo Rolon
This one?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
James B
The default Date of Issue in Project Info was removed due to the new Revision Management features. Any existing Date of Issue will be converted to a custom field and its data is retained. As mentioned, you can easily add a custom field.
James Badcock
Stephen Dolbee
Thanks to all. Now to check out Revision Manager.
ArchiCAD 18 New Feature Clips, Revision Management Playlist (46 clips):
https://www.youtube.com/playlist?list=PLnXY6vLUwlWVakX9gE_4eau0ClfPX1z8b
