4 weeks ago
- last edited
3 weeks ago
Switching the 3D editing plane on and off can be really annoying. Having to dig through Work Environment options to toggle it is far from ideal. It would be so much better to just activate the editing plane when needed by pressing a button in a palette, and then turn it off once editing is done. This seems like a simple feature to implement and would make working in Archicad infinitely more enjoyable.
4 weeks ago
It's already there?!
Or am I missing anything?
You can assign a keyboard shortcut for it, too.
3 weeks ago
Yes, the command is called "Editing Plane Display" and it is already available in the View menu. You can also assign keyboard shortcut to it in the Work Environment.
3 weeks ago - last edited 3 weeks ago
For my staff, I made a custom toolbar that includes that, and a lot of other useful things...
To set up a custom toolbar...
Go to Work environment->Command Layout Schemes-> Toolbars
Go to Toolbar Options->New Toolbar
In the list in the middle find the commands/buttons you want to add...
In older versions you click in the middle list and type, in Archicad 27 and above you can use the search field.
The hardest part is knowing the names of the commands/buttons you want to add.
You see you can also add menu groups as well.
In the example below tracker options - Gravity and Trace are menus with sub commands.
The menu shown above was for a 1920 wide screen(compact) when using laptops or doing presentations,
The example below is for a 2560 wide screen, so there are more options in the list below.
For me I added....
And remember to save it as a command scheme layout
And remember to save it as part of your active work environment, or the toolbar will not be available in the Windows->tool bars menu
An efficient work environment can save you a lot of time.
I hope this helps someone.
3 weeks ago - last edited 3 weeks ago by Barry Kelly
Didn't realize it was available as a shortcut key command!!! Nice.
Don't need to teach me about workspaces. I have my own with my own palettes and shorcuts. Didn't implement it in the english beta version because don't want to drag old things into the new interface. But never realized that something so deeply buried into the work environment would be available as a command.
My workspace. There are some scattered buttons here and there....
