2026-05-19
06:32 PM
2026-05-20
02:46 PM
We integrate typical doors (hosted in walls) and CW Doors (panels) in a single Door Schedule no problem, using Classifications as the criteria and the "Width" and "Height" general parameters as fields. An issue arises when the CW Door has a sub-frame and/or adapter with any width greater than 0". The Schedule sees the sub-frame and adapter as part of the panel, not part of the CW frame, therefore the width scheduled for the "door" is actually inflated. See below.
This screenshot shows a common CW door condition: 3-0x7-0 door, with 1" wide adapters, inside a CW frame. The door is 3'-0" wide, but is scheduled as 3'-2" (which is the door + adapters):
This seems to be mostly a Schedule issue, in that I need a different field other than the "Width" general parameter. I see that there is a "Nominal Width" parameter for Curtain Wall Panels, but in this example, it also returned 3'-2", so I'm not sure what that is intended to be used for? If a manually-input property is the only way to get both the model and schedule to work correctly together, I guess that is the work-around, but that sounds error prone. Any thoughts are appreciated!
There is also a separate issue that I can't have a sub-frame at the head be a different width than the sub-frame at the jambs... In the schedule above, the height of the door is listed as 7'-0", which is correct, but when inspected closer in the model, the door is actually 6'-11" tall to accommodate the adapter.
Operating system used: Mac Apple Silicon 15.7.4 Sequoia
Solved! Go to Solution.
Monday
It would still be more helpful, efficient, and BIM-oriented to have a dedicated parameter for leaf width/height that we could schedule (not including the adapters or sub-frame), but I did however eventually find a way to produce what we are after.
I ended up having to create specific profiles for the left door jamb, right door jamb, and door head, which include the appropriate width for either a door adapter or transom bar. This means there is a lot more fussing around with customizing the curtain wall frames around the door individually, which can be cumbersome and error-prone, but at least we can model true to construction and get the schedule to show the door leaf size correctly at 3-0x7-0 (most typically).
Those two things shouldn't have to be so difficult to accomplish simultaneously, but here we are.
2026-05-20 03:48 AM
Have you looked at library part parameters in the schedule scheme for leaf WxH? I know with cadimage, this is the easiest way to eliminate frame/inner frame from the schedule
2026-06-01 05:32 PM
I don't see a schedule scheme that fits that description. I think the primary cause is that Archicad considers this door a "CW Panel", not necessarily a "leaf".
Monday
