2021-09-30
07:46 AM
2022-09-23
12:04 PM
Oleksandra Vakariuk
I have a weird problem scheduling beam lengths.
I wanted to schedule beam lengths and totals for specified Complex Profile(s).
When I create a chedule without Complex Profile filter criterio, everything works fine (see attachment wo criteria).
After I specify my Complex profile, each beam lists four times. Filtering out Beam Segment Element does not do anything here.
What am I missing?
2021-09-30 11:22 AM
I've tried deleting all beams except one from entire project. From every layer and every renovation filter.
Schedule without Complex Profile criteria works fine (see second image). As soon as I add complex profile criteria, the beam gets listed twice (third image). Filtering out Beam Segment does not help either (fourth image).
2021-09-30 11:35 AM
I am missing something obvious, I just can't think what it could be.
I have exactly the same as you and I get just the one beam listing.
Can you try in a new file with nothing except the one beam?
You can export/import the schedule to save setting it up again.
Also what version and build of Archicad are you using.
I am testing in 25 build 3002 (I should update to 3011).
