FlappyBird
Schedule finish of wall, slab, column, beam
Hi All,
In Archicad, how can we schedule of finish layer of wall, column, slab, beam
Example Brick wall with finish layer
Beam with finish layer
Thanks
1 Solution
CosminF
Quick example: I made a column with a veneer on top.
Under the components schedule, I made this schedule:
And it shows like this:
hope this helps.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
2 Replies 2
CosminF
hope this helps.
FlappyBird
@CosminF
Thank you so much
