Suggestions on Best Practice for Interior Design Modeling
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2017-12-01
07:49 AM
2023-05-30
12:37 PM
Rubia Torres
2017-12-01
07:49 AM
Labels:
- Labels:
Project Management
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-01 08:28 AM
2017-12-01
08:28 AM
everything depends on what you want achieve.
I usually use
- layers for rendering purpose only.
- layers for elements VIP (Visible In Plan) and NO VIP to be shown only on the elevations/sections/3D view
In case you want to show particular furniture pieces (downloaded from internet) you maybe need to
1. clean the floor plan symbol
2. use two symbols: one for floorplan representation only and one for elevation/section/3D view ...
Generally all this can be achieved by use of layers.
This is my experience
I usually use
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Win 10 Pro 64bit
www.almadw.it
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-01 08:52 AM
2017-12-01
08:52 AM
Layers will allow you to turn elements on/off as required.
Set up layer combinations to quickly switch to what you need.
Also if you do not want elements in one layer to interfere (trim) with elements in another layer (even when that layer is turned off) then make sure those layers have different intersection priority numbers.
These numbers are also saved in your layer combinations so will need to be set there.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2017-12-01 09:15 AM
2017-12-01
09:15 AM
If I want to keep my model clean of impression stuff, I sometimes hotlink the whole PLN to a new PLN where I then put my 3D presentation stuff in there.
I generally do this when the libraries provided by furniture manufacturers and such 'polute' my project with lots of fills and surfaces created by those libraries.
I've also used your trick with renovation filters for people and plants and trees. I generally populate a 3D camera view with a bit of entourage that works for the composition of that view. These will most of the time not work for the next view, so I use your trick with renovation filters for each saved camera.
As Barry wrote above: keep your 3D archicad interior elements like walls, slabs, etc that will create connections with your model on a layer with seperate intersection number.
You will also want a seperate layer for 'lamps', not the actual fixtures, but the superior spotlight, IES light etc light sources that you need to light out your interior scenes in Cinerender, you do not want these showing up in your floorplan drawings and such.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
www.leloup.nl
Windows 10 Pro
