PT
proto
key command for drag copy?
When i right click for the popup menu to search under "Move" for the "Drag Copy" command, it shows a key shortcut of "option-command-D"
On a mac, when i press option-command-D, I don't get "Drag Copy"
"Option-Command" gives me "Inject Parameters"
& the D adds nothing
the right click menu selection is tedious
what am i missing?
Mac ACv29.2.0/5003, US, Tahoe26.5.1, 2021 iMac//2023 MacBook Pro//2025 Mac Studio
3 Replies 3
This is an issue with MacOS Big Sur - but maybe Catalina too? Whether it is something that the Graphisoft programmers could have programmed around (to give them priority over the keystrokes), I don't know...
The shortcut cmd-opt-D is pre-assigned by Mac OS to show/hide the dock:
https://support.apple.com/en-us/HT201236
Nothing I tried could get it unassigned from the dock functionality... and so ARCHICAD never even receives the key strokes.
The workaround is to assign a different shortcut to the command via the ARCHICAD Work Environment. In the attached, I'm about to assign cmd-shift-D to the command. Afterwards, that shortcut works fine.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Tahoe 26.6.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Eduardo Rolon
Karl it is hidden in System Preferences
Go to Keyboard->Shortcuts->Launchpad and uncheck or change "Dock Hiding…"
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thanks, Eduardo! I looked through everything there except "Launchpad..." (why dock hiding is there is a mystery!).
So, yes, proto, just uncheck the box shown in Eduardo's screenshot and the keyboard shortcut should work in ARCHICAD without redefining it as I did.
