GergoH wrote:
Now, I downgraded my Graphic card driver to 17.5.2, and now the 3D model works with OpenGL engine. So I think the new AMD driver (19.1.1) was bad.
My video card is supporting the OpenGL 4.5 version. (I checked it with OpenGL Extension Viewer 5.3.0) So I think that the problem was not the Open GL, but it was the amd driver.
Sounds like a driver issue for sure then.
GergoH wrote:
Do you think that it will be fixed in the next version? Because it worked well in the previous version.
Do you mean the next version of Archicad?
It would have worked in the previous version of Archicad (21) as that uses OpenGL 2.0 I believe.
And your 'new' driver was probably fine with this.
If 22 is now working with an older driver then it sounds like a driver issue rather than an Archicad issue - although I have no real idea as I am not that technically minded.
I am not sure if it would be an actual problem in the driver that the manufacturer would have to fix or if it is a tweak that needs to be made in Archicad to use the new driver.
