Sustainable design
About EcoDesigner, Energy Evaluation, Life Cycle Assessment, etc.
LCA plugin Finally here :) DesignLCA
Thomas Nymann
Hi
Graphisoft Center Danmark just released a public beta version of DesignLCA, a plugin to AC 26 that facilitates Eco designer star, in order to calculate a projects CO2 footprint throughout a given period of time (CO2eq/m2/anno)
DesignLCA calculates the "Global Warming Potential" as an "Early stage LCA"
With this method designers can (fairly) easy get a reading of your projects CO2 footprint where both construction and operation is taken into consideration.
There´s a Danish version, prepared to meet the danish regulations that will be implemented in 2023.
There´s an international version where vaules and settings needs to be adjusted to meet your local regulations, demands and EPD´s .
Feel free to download  the international version from this website: https://www.designlca.com/
The Danish version is part of our Localization, and can be downloaded from our website:
https://Graphisoft-danmark.dk/download
Please leave a comment if this could be usefull for studio.
ASUS ROG I9 12900H 🙂 - RTX 3080ti (16GB) - 32 GB RAM - Ryzen 7 1700X 3,8GHz. - GTX 1080ti 11 GB- 16GB RAM
AC 13 +
64 REPLIES 64
The international version of DesignLCA should work on all localized versions of Archicad. But DesignLCA will be in English only. It should also work with the German localization of Archicad.
We're almost ready with DesignLCA version 4.0, that includes energy from solar panels and also support Archicad 27 Beta 😄
undefined
Thank you this is great!
I have just installed the plugin with German template of Archicad and it works but I am missing DesignLCA materials, which are connected with Ökobaut, as you have here:
Is it possible to get these materials (even if it is in Danish language) or is there a way, we add our materials and connect them with Ökobaut? Since we don´t have any DesignLCA materials, we also do not have Environmental properties:
I could maybe set up  a German template with materials and connect them with Ökobaut, if you guide me a bit, how?
Thank you!!
You can download the Danish template for Archicad 26 here: http://graphisoft-danmark.dk/download#lokalisering
The Building Materials marked as DK/LCA is not based on ÖKOBAUDAT, but on a list of generic materials included with the Danish National Building Codes.
Please note that the Environmental Properties in the Archicad Building Materials are not used by DesignLCA. DesignLCA use the COe values in the Material LCA Settings of DesignLCA ...
Thank you!
I have now done test LCA calculations on a couple example projects and the stock doors and windows (that come in the DesignLCA package) seem to give a bit strange results. In both test projects the doors amount to 84 % of total project GWP and windows 0%. The numbers also seem to be abnormally high. Any idea what might be the reason for this?
Hi!
Sounds like a unit-problem. Make sure that the lenght unit in 'Calculation units' is set to meters. As for the 0% contribution from the windows, that might be due to the classifications. The windows need to have a corresponding classification with the properties in order for the calculation to work. I hope this is helpful! ðŸ˜Š
Wow, thanks for the super-fast response! Changing calculation units from mm to meters seems to have solved both door and window calculations. Thanks again!
Anna953
Beginner
Looks really cool and i try to use it for my master thesis, but my Building Material LCA settings are not updating with the EPD data from Archicad and I have already added the Design LCA library, but the values in the Building Materials LCA settings are all zero. Maybe this has something to do with the fact that the database comes from another country and is not updated in the German version and  is there a way to link the data here?
Thomas Nymann
Hi Anna.
We are glad you like DesingLCA
The LCA / Co2 values for Building Materials has to be added through the DesignLCA Building Material Settings:
Here you can set the unit as pr. EPD from which you get your CO2 values:
This is where the DesignLCA add-on reads the Co2 values, and NOT from the AC B. Materials Properties.
In our Danish Template we´ve already added ca. 100 Buuilding Materials, with the correct CO2 values, based on "Danish standards" and a list of generic materials, provided by our Building Regulations.
Our Template can be downloaded as part of our Localization here: https://www.graphisoft-danmark.dk/
Enjoy 😉
AC 13 +
Hi Anna
There is really no good way to add EPD or CO2 data from a database, because almost no databases has CO2 values for all phases/modules and does often not have the service life value. Another thing is, to do the energy evaluation (phase/module B6) the material also need thermal properties, that is all most never included in EPDs or EPD databases. To get beautiful drawings and 3D visualizations you also need line weights, fills and image maps, that is also not part of EPD data bases. Last thing is that name of the Building Material should match what you need for quantity take off and other Schedules.
Therefore DesignLCA will use the Building Materials from your existing Archicad template, and all you need to add is CO2 data for the phases/modules you need, the unit and the service life. – We believe this is the easier way to get a LCA from your model 🙂
Hi Thomas,
Is there a way to use LCAdesign for furniture in Archicad?
