Visualization
Cinema4 render engine? takes soo much longer
rob2218
just curious.....it appears the Cinema4 rendering process takes soooo much longer than the old "Lightworks" process.
Have any others noticed this?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
12 REPLIES 12
matthewjj
Bricklyne your renders look awesome! Would you be willing to share any of your secrets? Are you using the standard or physical engine with manual settings or are you using the default scenes?
During the beta testing I found that I preferred the physical engine over the standard because of the camera style settings (being a bit of an amateur photog). Most of my renders were test though so I haven't cracked the nut on a real project, so to speak.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
David Bearss
Quite impressive!
I too would be very interested in some simple steps to get further along with understanding your basic setups.
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
Most of my renderings average about 1 to 1.5 hours with ac 18
