HELP: Textures Not Aligning
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-02-09
06:01 PM
2023-05-11
01:01 PM
Noemi Balogh
For some reason over the past little while I haven't been able to get some textures to align. The most notable occurs with the face of the slab not matching the siding. This usually only occurs on 2 of the four typical sides of a building.
Any suggestions?
Thanks,
Gregg
(added in edit): I should add that in the past I was aware that this would occur if the slab was not perfectly aligned with the wall. As well I have set the textures of all elements to 0,0,0 to no avail.....
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 07:22 PM
gpowless wrote:I have noticed the same behaviour, especially in OpenGL mode. As the same happens in elevations and rendering, regardless of the engine, it probably means that the problem is deeper.
Also had quite a bit of problems with curved walls, where textures sometimes resized themselves horizontally.
Did not have time to test more, as a bunch of dedalines did not whooosh past ... but bared their teeth ...
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 07:30 PM
Have you tried using the texture editing tools under the edit menu?
See the attached image.
HTH.
Cheers.
Ben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 07:36 PM
Ben wrote:Ben, I did. Nada.
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 08:10 PM
Seems strange. I can get it to work as it should. Am I missing something?
Cheers.
Ben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 08:27 PM
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 08:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 08:51 PM
Link wrote:Agrrr,
It actually depends on which direction the walls were modeled. Turn off Options>Clean Wall & Beam Intersections and check the directions of the walls. I got 20 bucks that says they were modeled in opposite directions.![]()
Link.
I tried it and still got it to work. What am I doing wrong/right?
I, like Karl, have never had a problem with texture alignment.
Cheers.
Ben
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 09:01 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-02-09 09:15 PM
Link,
I public promise you that I have in no way altered any geometry in the file. All I have done is a texture alignment.
Cheers.
Ben
