Visualization
HELP: Textures Not Aligning
gpowless
For some reason over the past little while I haven't been able to get some textures to align. The most notable occurs with the face of the slab not matching the siding. This usually only occurs on 2 of the four typical sides of a building.
Any suggestions?
Thanks,
Gregg
(added in edit): I should add that in the past I was aware that this would occur if the slab was not perfectly aligned with the wall. As well I have set the textures of all elements to 0,0,0 to no avail.....
Intel i7-6700@3.4GHz 16g
GeForce GTX 745 4g HP Pavilion 25xw
Windows 10 Archicad 26 USA Full
20 REPLIES 20
Djordje
I have noticed the same behaviour, especially in OpenGL mode. As the same happens in elevations and rendering, regardless of the engine, it probably means that the problem is deeper.
Also had quite a bit of problems with curved walls, where textures sometimes resized themselves horizontally.
Did not have time to test more, as a bunch of dedalines did not whooosh past ... but bared their teeth ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Ben Odonnell
gpowless,
Have you tried using the texture editing tools under the edit menu?
See the attached image.
HTH.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
Ben, I did. Nada.
Djordje
HP Omen
Ben Odonnell
Mmmm,
Seems strange. I can get it to work as it should. Am I missing something?
Cheers.
Ben
Ben O'Donnell
Link
It actually depends on which direction the walls were modeled. Turn off Options>Clean Wall & Beam Intersections and check the directions of the walls. I got 20 bucks that says they were modeled in opposite directions.
Link.
Yeah, I'm confused as well as to how these problems would arise... I've yet to encounter an alignment problem that I couldn't fix, but rarely need to do anything special.
Ben Odonnell
Link.
Agrrr,
I tried it and still got it to work. What am I doing wrong/right?
I, like Karl, have never had a problem with texture alignment.
Cheers.
Ben
Ben O'Donnell
Link
Knock yourself out mate.....!
Link.
Ben Odonnell
He He,
Link,
I public promise you that I have in no way altered any geometry in the file. All I have done is a texture alignment.
Cheers.
Ben
Ben O'Donnell
