ā2023-06-20 07:57 PM
See attached image.
I like to model all the tiles in my houses for scheduling, estimating and communication purposes. The prism26 object is almost exactly what I need but I cant rotate it in view to set which side of the tile should be at the bottom.
Is there a trick to getting it to rotate like shown here:
ā
ā2023-06-20 10:48 PM
Why don't you create a custom profiled beam with the shape of your tile (if you want to use it for walls).?
You can rotate then to any angle with the beam axis rotation....
ā2023-06-20 11:23 PM
I don't use beams much so I never thought of it as an option, would be nice if the hex object had the ability to rotate as needed because regardless of application, the one way to apply wont work in every case so this flexibility seems like a good option to have built into the object. At least they added some ability to rotate, hopefully this gets added eventually
ā2023-06-20 11:37 PM - edited ā2023-06-20 11:38 PM
Change it then to a morph, rotate it and save it as an object. Another way. Don' t forget to adjust the correct thickness.
ā2023-06-22 08:07 PM
Thanks, I'll look into morphs, havent tackled how to use those yet
