2025-09-10 02:07 PM
I'm having several problems with the Maxon render engine of archicad that closes every time I try to use it. I've already tried to restart archicad, I also reinstalled the add on and installed the latest update of archicad 28. How can I solve it?
2025-09-10 08:57 PM
Are you on macOS 15 Sequoia?
There is a Cineware issue there. For details and the workaround, see this article:
https://community.graphisoft.com/t5/Installation-update/macOS-15-Sequoia/ta-p/616173
2025-10-15 07:25 PM
I have tried that workaround repeatedly, most recently yesterday, and it doesn't work for me.
Steve
2025-10-15 07:48 PM
If you have replaced the Cinerender folder with the working one also delete the Redshift folder within and it should then work. Make sure Archicad is closed or restart after you have e deleted the Redshift folder.
2025-10-16 01:32 AM
I had not deleted the Redshift folder. It is working for me now!
2 weeks ago
Lee Hankins, could you please tell me where I can find the working one folder to replace (cinerender folder)?
2 weeks ago
Follow the link in Laszlo's post.
Or to make it easy,,, https://graphisoft.sharefile.com/share/view/s0047a28b64a742b8930f768c6faf2a98
2 weeks ago
Thank you Barry Kelly. I followed instructions and It works perfectly. Thank you very much
