2025-09-10 02:07 PM
I'm having several problems with the Maxon render engine of archicad that closes every time I try to use it. I've already tried to restart archicad, I also reinstalled the add on and installed the latest update of archicad 28. How can I solve it?
Solved! Go to Solution.
2025-10-15 07:48 PM
If you have replaced the Cinerender folder with the working one also delete the Redshift folder within and it should then work. Make sure Archicad is closed or restart after you have e deleted the Redshift folder.
2025-11-03 12:43 PM
Follow the link in Laszlo's post.
Or to make it easy,,, https://graphisoft.sharefile.com/share/view/s0047a28b64a742b8930f768c6faf2a98
2025-09-10 08:57 PM
Are you on macOS 15 Sequoia?
There is a Cineware issue there. For details and the workaround, see this article:
https://community.graphisoft.com/t5/Installation-update/macOS-15-Sequoia/ta-p/616173
2025-10-15 07:25 PM
I have tried that workaround repeatedly, most recently yesterday, and it doesn't work for me.
Steve
2025-10-15 07:48 PM
2025-10-16 01:32 AM
I had not deleted the Redshift folder. It is working for me now!
2025-11-03 10:49 AM
Lee Hankins, could you please tell me where I can find the working one folder to replace (cinerender folder)?
2025-11-03 12:43 PM
2025-11-06 12:11 PM
Thank you Barry Kelly. I followed instructions and It works perfectly. Thank you very much
2026-01-06 08:29 PM
Hi Folks,
Why do I have to continue to do this patch every time I install a new AC hot fix. Pretty frustrating.
Any idea when this fix will be made permanent?
Thank you.
John Adams
iMac, 3.8 GHz 8-Core Intel Core i7, MacOS 15.4.1 (Sequoia)
2026-01-06 11:21 PM
It’s because the updates reinstall the missing folder. Apparently it’s scheduled to be fixed in Archicad 30.
