Antimo_11
Maxon's cineware add-on closes unexpectedly on Archicad 28 for Mac
I'm having several problems with the Maxon render engine of archicad that closes every time I try to use it. I've already tried to restart archicad, I also reinstalled the add on and installed the latest update of archicad 28. How can I solve it?
2 Solutions
Lee Hankins
If you have replaced the Cinerender folder with the working one also delete the Redshift folder within and it should then work. Make sure Archicad is closed or restart after you have e deleted the Redshift folder.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
Follow the link in Laszlo's post.
Or to make it easy,,, https://graphisoft.sharefile.com/share/view/s0047a28b64a742b8930f768c6faf2a98
Go to post
10 Replies 10
Are you on macOS 15 Sequoia?
There is a Cineware issue there. For details and the workaround, see this article:
https://community.graphisoft.com/t5/Installation-update/macOS-15-Sequoia/ta-p/616173
svpribyl
I have tried that workaround repeatedly, most recently yesterday, and it doesn't work for me.
Steve
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
svpribyl
I had not deleted the Redshift folder. It is working for me now!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
charmingman12
Lee Hankins, could you please tell me where I can find the working one folder to replace (cinerender folder)?
charmingman12
Thank you Barry Kelly. I followed instructions and It works perfectly. Thank you very much
John Adams
Hi Folks,
Why do I have to continue to do this patch every time I install a new AC hot fix.  Pretty frustrating.
Any idea when this fix will be made permanent?
Thank you.
John Adams
iMac, 3.8 GHz 8-Core Intel Core i7, MacOS 15.4.1 (Sequoia)
Lee Hankins
It’s because the updates reinstall the missing folder. Apparently it’s scheduled to be fixed in Archicad 30.
Lee Hankins
macOS Tahoe (26.0)
