Wishes forum
Better distribution
runxel
Mentor
If you want elements to distribute the function I need the most is that the computer automatically figures out how much distance between their bounding boxes is - and then aligns the objects accordingly.
The distribution in Archicad however works different.
Instead Archicad takes the middle axis of the element and distributes those (so the distance between the axis are the same, but different between the elements themself - I want it the other way around).
It would be great to have the option to choose one of these methods.
AC 24 [ger] | Win 10 | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Runxel,
I think I understand what you are wishing for but could you also attach a screenshot that illustrates this wish?
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
runxel
Mentor
Sure! I've updated the wish with a screenshot which makes it obvious how Archicad's method is rather suboptimal in some cases.
OK, this is not what I thought, so it is good that you attached that screenshot.
So you basically distribute the elements between the two farthest elements of the selection so the gaps between the elements will be the same regardless of variation on the widths of elements in the selection.
