2004-01-10 08:45 PM
2004-01-11 02:16 PM
2004-01-12 05:20 PM
MSotero wrote:I think this should be selectable as Layer Combo or Display settings. The combination of Layer Combo, Display Settings, Scale and Pen set would be defined in the Quickview
3) Mostly I see the setup names appearing in the Layers dialog box as a popup (value list if you will) where one could select it for use in connection with the Layer. This selection would be part of the whole Layer Combination option. For example to create an Electrical plan, one could select BasePenSet (named as such for explanatory reasons) as part of the Layer Combination and instantly your walls would appear completely differently. I’d prefer this over the ghost stories method as you would not be limited to single pen and you don’t need to create additional stories to get you there. In addition, I like to have the outer wall pen print a slightly darker gray than the fill it contains on my base drawings (which is why I want Pen Sets and not a simple Layer Pen).
MSotero wrote:And the layer state (printing/non printing) should be saved in the layer combo
4) Provide a Non-Print Toggle as part of the Layer options. This setting doing just what it says namely, it makes items of that layer visible on screen, but like a Hotspot, won’t print. I’d see the Non-Print option having a single user definable pen color similar to ghost stories (or maybe just use the ghost story pen). This Toggle also working in connection with the Layer Combination choices. This way one could have a preferred way of making a template/guide system and optional ways of viewing things.
