Thursday
When working on a drawing, there are times when cut marks or floor-down marks on a 2D
drawing are finished in 2D. It would be nice to be able to add frequently used 2D objects to
favorites and use them.
Friday
Favourites do not store actual 2D elements such as lines and fills.
They just store the settings (pen, layer, etc.) for those elements, so you don't have to set them up yourself.
Favourites can store objects and their settings so you can easily place the object you want, but they can not store objects as well as extra lines and fills as one.
For that you want to look at modules.
Save the object and extra 2D line work as a module that you can then use over and over again.
