Due to a scheduled maintenance, a maximum 20 minutes license delivery outage may be expected on July 6 2024 (Saturday) between 6PM to 8PM (CEST).
Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Calculator
I think a calculator would be a good idea.
A calculator that you could have show up on each screen and info box etc in which you were working. Something like a a share trading portfolio screen that stays with you. This would be useful when calculating heights for walls, slabs, mesh points, etc.
AC is nice and accurate but it would be good to have the tools to help in creating the accuracy IMO.
21 REPLIES 21
Jefferson wrote:
Addition seems to function fine but subtraction yields mixed results, ... For subtraction for instance if I type 5- I get a result of 5' not the subtraction of 5'.
I vaguely remember reading somewhere that you can type a double minus.
i.e. 5--
The first gives you the 5 feet nothing and the second does the subtraction.
Not sure if this is correct as I live in the decimal world, but thought I had seen this some time ago.
henryL
This is a very old post to revive. I think that every number field should be an inline calculation field
