Read more
Wishes
Grasshopper - Archicad Connection | Curtain Wall Frame Settings to be expanded
Josh Verran
In the Grasshopper - Archicad Connection, the Curtain Wall Frame Settings node only has the 9 inputs Type and Geometry settings:
  • Class Name
  • Width
  • Depth
  • Offset
  • Depth of Inset
  • Width of Inset
  • Intersection Priority
  • ID
  • Property Settings
We also need the other Curtain Wall Frame settings:
  • Building Material
  • Pens
  • Linetype
  • Override Surface
I suspect the Panel Setting has a similar lack of settings
GRAPHISOFT CERTIFIED ARCHICAD BIM MANAGER | LinkedIn | My Top Wishes
ARCHICAD 18-27 | BIMcloud Basic | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Perth, Australia and Tauranga, New Zealand
Windows 10 Pro | Intel Core i9-9900K @3.60GHZ | 32Gb RAM | 2xSamsung S27F350 1920x1080 60Hz | Nvidia Quadro P2200 (5Gb)
0 REPLIES 0
