Read more
Wishes
Level Dimension to Reference Level (sea level)
Can we please-please have the option to choose to reference the level dimension to a reference level other than project zero BEFORE we place the marker on plan?
I know there's a work around to change the dimension text after the level dimension has been placed but I would like to see it as an option to be selected in the tool's settings PRIOR to placing the level dim on plan...
I don't understand why it is not there already, the option is available on the (normal) dimension tool when one chooses the 'elevation dimension' then one can choose 'dimension origin'... so why is it not there on the Level Dimension tool is really beyond me!
33 REPLIES 33
I wanted to say that you should switch to 1st Reference Level in the Project Preferences Dialog but then I tried and it indeed always references the Project Zero.
So I voted essential, and I say this should work like this for Elevation Dimensions in Sections/Elevations, too, not only Level Dimensions.
Thanks Lazlo
If I understand you correctly, the Elevation dimension strings on section/elevations already work this way... it is just the Level Dimension tool (which only works on plans) that does not have this ability to choose to which ref level you want it to dim to...
xristina wrote:
Thanks Lazlo
You are right, my bad. Have not checked it.
Guys,
Could you please support this topic with a few screen shots to make me understand you 2 clearly , I think I fight with the same challenge.
Thanks,
o.k. I got it , unfortunately couldn't find the way around it yet.I agree it'd be absolutely essential.
Has there been a fix for this, or is there a work around you suggest.
Thanks,
Jordan
Type in the 1st reference level as see level - but in negative - so to put the level relative to project 0,0, than in level dim add the proper autotext.
remember to use correct units (the model units)
Best Regards,
Piotr
Erika Epstein
You can set the level dimension relative to one of the reference levels. AFTER you place it, select it and pick the AUTOTEXT option (instead of Measured Value or Custom Text), This will give you the option to select the reference level you want.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Just bumping this old post to maybe get more response.
Most definitely a need to be able to adjust the custom text before placing a level dimension (or any dimension come to that).
We can't even save the custom text as a favourite which would be a work-around.
